Anyone had experience with spring cage repairs and can suggest suppliers for springs, clips etc or should I just get foam? If foam what base do you mount it on? Thanks...
I've repaired quite a few of these now.
The frame itself is just mild steel I believe so can be repaired with mild steel cut down to the right size and welded in.
Here's a beetle frame I did a few years back.
Before:
James, thanks for the kind offer but I've put an order in for some bits from here https://www.upholstery-supplies.co.uk/
Hopefully this should do it. Going to try replace a few springs but might end up pinching from one seat to repair the rest and then re make one as the springs probably won't match exactly! Fingers crossed it can't get any worse!
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
