Refitting heat duct 'Y' over torsion housing
Post by vwJim » Sat Feb 08, 2020 8:12 pm
So has anyone done it to a bus with the floor fitted / fully painted bus?
I've only ever done it with the floor out. So how did you do it / or photos of something non standard on your current bus?
Re: Refitting heat duct 'Y' over torsion housing
Post by BlastingDiePast » Wed Feb 12, 2020 10:30 pm
If it’s a non original floor you need to in large the floor holes to fit it, it’s quite brutal as they don’t like being retro fitted.
Post by vwJim » Fri Feb 14, 2020 10:51 am
That's what I was thinking. Not going to be easy to do neatly
Troytempest69
Post by Troytempest69 » Sat Feb 15, 2020 11:24 am
Will, this is one of the jobs that needs doing to franklin/gee gee. Early 50mm tubes fitted as that's all I could find at the time, but now got the correct, later, 60mm tubes (one in your garage and one just delivered from evam). The 50's were a pig to get in, especially as the repro floor pan didn't even have the holes cut for where the heater tubes bulge out from the floor.
BJ1
Post by BJ1 » Sat Feb 15, 2020 2:55 pm
I did it years ago by slitting the Y duct horizontally, getting it in place and welding it up. It was a PITA.
1966 Westy in Velvet Green - being restored
1967 Devon from Devon still in Devon
1967 Sundial from Idaho
1971 Westfalia from LA
1971 patina Delux from Montana now living in Germany
1972 Devon now owned by No 1 son!
