Burt 67 11 window
Burt 67 11 window
Post by BlastingDiePast »
Here is Burt a late lhd Splitscreen.
We pulled this from its hiding place last weekend, it’s been sat for 8 years in a barn in the U.K. since being imported from California.
Needs only the rear corners the battery tray, dent in the nose pulling and a few sections of cargo floor apart from that it is solid, no chassis rot, Swartz or sealant, pudding etc
Full repaint then a rebuild with new parts, it has a balljoint front beam which looks to have been almost factory fitted...
Anyway this will have a huge amount of detailing and time spent panel beating rather then replacing panels.
Re: Burt 67 11 window
Stripping the bus down.
Stripped ready for blasting on Monday
Post by markp »
Looks in good condition :cheers: :cheers: :cheers: :cheers:
How did it look after blasting :bounce: :bounce: :bounce: :bounce: 8O 8O 8O
Mark p
Super solid chassis! Only issues are the ones we knew about and a couple of pin holes.
The rear corner damaged has effected the drivers long panel just at the very end just below the bottom vent so that’s coming out and the wheel arch straightened out, rear corners off and battery tray out. New long panel section found and cut ready and we are almost ready to weld up the rear end.
Couple of panels arrive, welding in tomorrow
New cargo floor section, sill and inner strengthening panel installed to the bus
Rear corners test fitted, as no 66-67 model engine kids are available we are going early style to keep the bus on track!
Moved onto the bulkhead area, cut away what was left of the original and test fitted then adjusted the new donor section ready for welding in now.
New bum for Burt
Just the front windscreen lower lip and safari brackets to weld in and it’s ready for paint prep.
Seems a popular colour at the moment.
Chassis painted, body in high build ready for flatting.
