For the attention of anyone with a Tracker....
Anything aircooled which gets arf inched
Post by vwJim » Thu Oct 11, 2012 4:50 pm
Following the recent theft of the bus with a tracker fitted, it reminded me that if you call Tracker up, they can do a PING test of your system to make sure its currently working and not reporting any faults etc.
Plus, they often fail / need a services after 5 years but Tracker don't contact you if the unit goes down, its down to you to check with them and book their engineer to service it. So well worth a yearly call to make sure its working.
Paul66spliy
Re: For the attention of anyone with a Tracker....
Post by Paul66spliy » Thu Oct 11, 2012 7:20 pm
Yes Jim
It pays to have a service, keep it all up and working currently working as you say
Paul
Sjtw
Post by Sjtw » Fri Oct 12, 2012 8:23 am
I'm looking to getting Tracker fitted on my new bus, how badly does it drain the battery over the winter when the bus isn't running? Or is it not a problem?
Steve
Sooty
Post by Sooty » Fri Oct 12, 2012 8:43 am
No problem at all.
Mine even calls me when my battery is getting low! 8)
'NEVER SACRIFICE WHO YOU ARE JUST BECAUSE SOMEONE HAS A PROBLEM WITH IT'
SPLITLESS...
The last 5 years! viewtopic.php?f=8&t=44037
Sjtw
Post by Sjtw » Fri Oct 12, 2012 9:08 am
That is music to my ears, I'm picking up my first camper this weekend and of course, I'm totally paranoid about loosing it. Mainly down to reading posts by you Sooty actually :)
Which level of tracker do you think's best, quite like the one with VHF & GPS too so I can see it on my phone, but its quite expensive.
Steve
Geocamper
Post by Geocamper » Fri Oct 12, 2012 5:28 pm
I have a skytag fitted.Does everything it says on the tin.Excellant value for the money.
paul_f
Post by paul_f » Fri Oct 12, 2012 5:35 pm
Anything that works via a SIM card can be blocked with a 20 quid device...
kombie 454
Post by kombie 454 » Fri Oct 12, 2012 5:45 pm
How much are the trackers that operate non sim, I take it you pay for the unit and then a monthly fee ?
Well I'm standin' on a corner in Winslow Arizona,
Such a fine sight to see!
Oh there's a girl my lord in a flat-bed ford,
Slowin' down to take a look at me! .....................( Wish I'd written that! )
65' Devon "Bubba"
64' Mostard
72' Westy Trailer
52' Es2 Norton
Sjtw
Post by Sjtw » Fri Oct 12, 2012 6:04 pm
I've looking at one called 'tracker'
250 to have it installed and an annual fee of £99. That's aVHF one that can't be blocked. You tell them as soon as you discover it's stolen an they track it and alert bizzies. You can't see it on your computer or have it alert you if it's moved unless you upgrade to the next one which is £179 a year and a bit more for the install.
Steve
Post by vwJim » Fri Oct 12, 2012 8:25 pm
Sjtw wrote:I've looking at one called 'tracker'
With Tracker, you can pay more initially and not pay a yearly fee if the vehicle is a 'keeper'
ziggy
Post by ziggy » Sat Oct 13, 2012 6:31 am
paul_f wrote:Anything that works via a SIM card can be blocked with a 20 quid device...
And the sim needs a reception just like a mobile phone, if the vehicle is in a dead spot it can't be detected
glennbroadway
Post by glennbroadway » Sat Oct 13, 2012 10:38 am
I'm a bit confused. GPS is not linked to a SIM. Location based on cell tower (i.e. via a SIM) is not very accurate... Do the cheap signal blockers block cell coverage or GPS?
Also, does Skytag use GPS or a SIM?
paul_f
Post by paul_f » Sat Oct 13, 2012 11:50 am
You can get blockers for either GPS and GSM. Both are illegal... You can probably get combo ones as well
Most GPS trackers send the information via the GSM network
paul_f
Post by paul_f » Sat Oct 13, 2012 11:54 am
orb
Post by orb » Sat Oct 13, 2012 1:53 pm
Just had one fitted to mine that doesn't use GPS so is apparently a bit more difficult to block.
Details on this recent thread.
viewtopic.php?f=2&t=88526
Orb
My Bus - http://www.youtube.com/watch?v=K7deu8L0ra4
PB 15.126 @ 83.26 mph EBI 2015
