slammed tyres
spliterik
slammed tyres
Post by spliterik »
Just treated my bus to a 41/2" narrow beam and dropped spindles. Currently running on 15's whats the smallest tyre (width and depth) that i could use ? Not too bothered about a harsh ride !! and does anyone know who supplies them ? i was told to use 165,45,15 but cant seem to get hold of any , thanks.
Tom1964bus
Re: slammed tyres
Post by Tom1964bus »
165/50/15s mate.... as far as im aware there isnt a huge choice in brands, i saw nankangs and bridgestone when i got mine, i opted for the later and they werent cheap!! 60 odd quid each i think..fitted etc..
fiftyeight
Re: slammed tyres
Post by fiftyeight »
i have the bridgestones that what i paid for them good tyres
moler
Re: slammed tyres
Post by moler »
Try a search at mytyres just found a 165/45x15 made by Federal for £37 8O
8)
fiftyeight
Re: slammed tyres
sweet tyres from mytyres moler :wink:
berpsta
Re: slammed tyres
Post by berpsta »
yup id use mytyres all day long think i got some of the nankang ones for 32 quid a piece
Sean
Alabama 60 11 window
Slo-Val 55 Oval
spliterik
Re: slammed tyres
Post by spliterik »
thanks for that guys . 8)
vwbuzzers
Re: slammed tyres
Post by vwbuzzers »
I get the bridgestones locally for £50 fitted most local companies will price match
Gruntilla
Re: slammed tyres
Post by Gruntilla »
Hi chaps
What tyre pressures do you run your slam tyres at?
Grant
SBS UK # 10
nodding dog68
Re: slammed tyres
Post by nodding dog68 »
Gruntilla wrote:Hi chaps
Grant
gotta be low :lol:
os1624
Re: slammed tyres
Post by os1624 »
Grant
gotta be low :lol:
You beat me to the question! I know that it seems lame but I've been having problems with my tyre pressures recently. My front wheels are currrently wearing Bridgestone 165/50/15. I know that its a bit of a bone shaking ride but I still have some doubt regarding pressures.
So what are the skinny rubber brigade running with?
ben
The Blaupunkt Bus '66 11 Window Swedish Import The closest I'll get to a Swedish Blonde!
moler
Re: slammed tyres
Post by moler »
I run 30 psi in the front, but mine are 185/55x15 :)
malachai
Re: slammed tyres
Post by malachai »
I have 175/55 at the front at 28psi, I can't remember what size at the back but its 32psi, I went for the stock pressures since I didn't see any reason not to, is there a reason not to?
torpointboy
Re: slammed tyres
Post by torpointboy »
I ran Smart car tyres as seen below in the pic, but the bus handled like a Blackpool Tram, and in the wet........Shudderingly Awful!!
maddison
Re: slammed tyres
Post by maddison »
1stly...if your wanting narrow as you originally posted , then 145/65/15 are the narrow option
165/45/15 have smaller hieght walls (lower bus) but not as narrow as 145 which still have a reasonably low profile wall
secondly...i always thoguht the smaller volume the tyres, the less air they hold so the higher the pressure
i.e...if you have 30psi in your 195/65/15 rears you should have about 40 in your smaller front tyres due to the fact it has less square inch volume but still needs to support the same weight
