Flywheel help
rickyday33
Flywheel help
Post by rickyday33 »
Hey guys,
My dad has a type 3 case engine engine code AS41(?) We have just tried installing it in his van. the bus has the original gearbox. The flywheel seemed to be too big. I have read through some old posts and Laurie Petit stated that engines with the AS code have a 215mm flywheel. Could I just fit a 200mm flywheel?
thanks :D
rickyday33
Re: Flywheel help
anyone?
geldof
Re: Flywheel help
Post by geldof »
yep 8)
torque it up though, and would be worth throwin in a new seal + O ring while you're at it :wink:
Laurie Pettitt
Re: Flywheel help
Post by Laurie Pettitt »
Ignore as 41 and all that. The engine number should start with AS not the part number. Chances are you have a 12 volt flywheel that you are trying to fit into a 6 volt bell housing. Its a case of grinding it out for the flywheel and fitting a 12 volt starter. Any probs, the number is at the bottom.
Laurie Pettitt. 07824514205
nodding dog68
Re: Flywheel help
Post by nodding dog68 »
Laurie Pettitt wrote:Ignore as 41 and all that. The engine number should start with AS not the part number. Chances are you have a 12 volt flywheel that you are trying to fit into a 6 volt bell housing. Its a case of grinding it out for the flywheel and fitting a 12 volt starter. Any probs, the number is at the bottom.
yep :wink:
rickyday33
Re: Flywheel help
thanks guys, will get the grinder out!!!
