Swing Axle vs IRS Technical Topic
chunkynichols
Re: Swing Axle vs IRS Technical Topic
Post by chunkynichols » Fri Sep 03, 2010 5:51 pm
Can you IRS or Sa to a stock gear box?
bobley
Post by bobley » Sat Sep 04, 2010 8:02 am
You cant use a stock box as is. You need to pull it apart and flip the differential over otherwise you'd have 4 reverse gears.
A stock box with a flipped diff would then be usable in an SA setup. To use it in an IRS setup would require changing the side plates and diff components. It would be much easier to use a stock beetle IRS box and switch the nose of the stock box onto it.
chunkynichols
Post by chunkynichols » Sat Sep 04, 2010 11:32 am
To do the IRS conversion with a beetle box does the nose of the stock box fit straight onto the beetle box or does it require adaptors? Is there an age of beetle that has the right gearbox ie anything before 1970?
moler
Post by moler » Sat Sep 04, 2010 8:34 pm
chunkynichols wrote:To do the IRS conversion with a beetle box does the nose of the stock box fit straight onto the beetle box or does it require adaptors? Is there an age of beetle that has the right gearbox ie anything before 1970?
The stock Split nose cone fits straight on to a Bug box.
It's not an age of Beetle, but the type, you need to be looking at boxes from 1302's, 1303's, and late type3's.
Surfbus
Post by Surfbus » Mon Sep 06, 2010 11:27 am
Can anyone tell me the difference in accelleration and top speed for rpm with the different gearboxes?
ie 4.375, 4.125, 3.875 ?
I have no idea what these mean. I currently run a 1641cc bus but at some point will go bigger.
Think I currently have a 1500 SA box but its started jumping out of 4th gear cruising at 3000 revs so its time for a used replacement but didnt know what changes a different box would make.
Cheers.
raiz
Post by raiz » Mon Sep 06, 2010 12:49 pm
Surfbus wrote:Can anyone tell me the difference in accelleration and top speed for rpm with the different gearboxes?
Cheers.
Whats your rim and tyre size too :wink:
SBS UK#25 Image
Surfbus
Post by Surfbus » Mon Sep 06, 2010 5:11 pm
Tyres are currently 175x65x15inch
Was thinking of putting some 185x60x15inch on as I have 2 new yokahamas in that size.
j0hn
Post by j0hn » Mon Sep 20, 2010 10:49 pm
Thought I'd post up here rather than start a new thread in the main Tech forum.....
I'm after a bit of advice needed regarding gearbox choice for the bus.
I've managed to gather up most bits for a stright axle conversion now - need bearing caps, and most importantly a gearbox! :?
I'm running a 2007cc Berg motor so got plenty of grunt for pushing along. Tyres are 175x65x15.
I want a box that'll cruise away nicely on the motorway at 65/70 without screaming the engine.
1500 boxes seem to be recommended (or the nice rancho that's on VZi ;) ) but obviously cost more, and they all seem to be miles away from the North East :roll:
I've seen a cheapish 1300 box out of a mexican '82 bug with 40k on it - but it is local and under a ton. Would this be too low geared for my needs?
Or one final option - could I Frankenstein it a bit and put the diff out the the old gearbox into the 1300 'box for a better ratio ('67 large nut RGBs)? If so how easy is this?
Anyone got experience with running one or the other?
Cheers,
j0hn
Splittist
Post by Splittist » Sun Sep 26, 2010 12:34 am
Well I've just managed to buy a 1500SA gearbox and axles etc only to come across a '64 type 3 gearbox and axles a week later ... so I've now got a spare gearbox - all polished up like a tart! Anyone interested, I want £150 for it.
But that's not the reason I'm posting. I'm looking at the prices of the SA lowering kits and they seem disproportionately expensive, you usually pay the same price in pounds as they are in dollars and you get accustomed to that, but US price for the bus boys kit is $350-ish, so why the **** do we have to pay £460 odd for them in Blighty?
How easy is it to modify the axle sleeves yourself? What are the mods that the likes of Bus boys are doing to their axle sleeves? The spring plate rework look easy enough, that could be done in a machine shop. And then what do you need, a few gaskets etc?
Maybe I'm just being tight fisted, but if one of you bright sparks could point me in the right direction, it would be appreciated. :D
1957 dove blue Kombi
1957 Strato blue oval bug
j0hn
Post by j0hn » Sun Sep 26, 2010 3:45 pm
Could be interested in your gearbox. :)
I believe the BusBoys kits use the "correct" length tubes - i.e no bodged offset spring plates.
You need the end castings from a set of short tubes, and a set of modified length tubes - you need two sets of tubes to make these. Overall length should be 21 7/8" for the tubes.
I was planning on doing this myself and have collected a set of short tubes and also some long end casting tubes - but in a similar twist of fate as your gearbox - shortly after I managed to get hold of a ready done set :wink:
Perhaps we could come to some sort of arrangement?
PM me so we don't clutter up a tech thread :)
Cheers,
John
raiz
Post by raiz » Thu Sep 30, 2010 4:04 pm
So i'm going Porsche IRS ive got bug irs box and will be narrowing torsion on Porsche arms...
Its the drive shafts im unsure on?
i have Porsche 944 shafts can i use these?
SBS UK#25 Image
Splittist
Post by Splittist » Mon Oct 04, 2010 10:52 pm
So it's all kinda falling into place ... one thing that I'm still wondrin about is spring plates. Being the skinflint that I am, I'm not paying for a bus boys kit when all of this stuff can be sourced.
So can someone tell me what spring plates are suitable, are we just talking late standard type 1 swingaxle? ie without the sticky out bit.
thanx :wink:
OK - I've been advised that I can use my bus spring plates modified to match the corresponding bolt pattern on the short end castings.
Chief_Wiggum
Post by Chief_Wiggum » Mon May 23, 2011 12:52 pm
I have a straight axle setup on my bus, with a 1500 beetle gearbox. The axles are perfectly horizontal (2 splines down I think) at the moment, so can't really go higher or lower without messing up the camber (or affecting oil levels at the bearings)
I've gone a bit lower than I intended though, as I'm always scraping by exhaust and can't easily get the wheels on or off. Considering switching to a Boxwagen IRS setup because presumably this means I can run a couple of inches higher without messing up camber? Or am I just kidding myself? I could just get bigger tyres!
BTW- definitely not going back to RGB's - driving on motorways is so much nicer now.
jambo
Post by jambo » Fri Jun 24, 2011 6:10 pm
Evening
lookin to IRS my 67 bus, which would be the best kit to go for ? also what final drive would be good ? would like the usual be able to cruse at 70 i am running a 1776 at the mo but may go bigger next year, running 15 wide 5's 185 55's well that what the wheels came with.
any ideas ?
many thanks Jambo
jambo
Post by jambo » Fri Jun 24, 2011 6:19 pm
vwJim wrote:Yes, seen that on a few buses, and will be using that system soon on another.
Like it as there is camber adjustment that you can dial in once its all fitted.
VW Jim did you fit one of the those kits in the end ? if so would you mine me askin if it was any good ?
Cheers Jambo
Oh i take it you were refiring to the box wagon kit ?
