Efi advice needed.
Eternal Optimist
Efi advice needed.
Post by Eternal Optimist »
I’ve got a 1776 built up and I’ll be using Mexican efi kit on it. I’ve been planning this for a long time, just looked at the receipt for the Megasquirt ECU kit and it’s dated May 2013. It’s a MS1 v3 kit which is now obsolete.
I’m planning on using Ford EDIS which I don’t think is supported by MS1 v3.
I don’t mind soldering, so kits are OK and I don’t mind buying something built up.
What’s the current thinking around ECU choice?
Eternal Optimist
Re: Efi advice needed.
Blimey, it’s gone a bit quiet on here. It’s a few years since I was a regular, but what’s happened? Has Facebook taken traffic away from the forum?
philsparks
Post by philsparks »
Keep the faith, its still good.
I'm not sure how many of us know about efi kit.
It's the old school version on here.
Phil
Sent from my HRY-LX1 using Tapatalk
FB has taken a lot of traffic off all forums. But as there's no search function you get the same questions over and over.
Qualify not quantity here ;-)
If you're happy to self build again, megasquiirt has all the features, and in some cases more, then the other brands.
Definitely go full EFI though and include ignition control.
PS I think megasquiirt is the only one that understands logarithmic TPS signals.
Eternal Optimist
Thanks Jim
paul_f
Post by paul_f »
Have you already got the Mexican EFI kit? I have a set I am going to sell
Eternal Optimist
I’ve had it since 2013 if not earlier!
Why not just use the version you already own? I bet it'll still do the job.
Eternal Optimist
I think I read the version I’ve got isn’t compatible with EDIS. I’ll keep reading up. If it isn’t, I’ll use it on the Standard 10 I’m building instead of using it on the VW
Eternal Optimist wrote: Sat Jul 04, 2020 8:21 pm I think I read the version I’ve got isn’t compatible with EDIS. I’ll keep reading up. If it isn’t, I’ll use it on the Standard 10 I’m building instead of using it on the VW
How does it control ignition then? Thought they all did wasted spark. Is that version just fuel control?
Eternal Optimist
I might be wrong Jim Re EDIS. It definitely does fuel and ignition, I think I read something that said the version I’ve got doesn’t drive EDIS. I did buy them both at the same time so it was always the plan to use EDIS with the Megasquirt controller I’ve got. I’ll get it built and report back.
