How do people deal with/fix stripped sump bolt threads?
Doka Dave
Post by Doka Dave »
Hi all,
been watching oil drip while my bus is standing cold and it appears to be coming though alongside two of the six sump bolts (the little 10mm ones with the brass washers). How can I fix this? The bolts are only supposed to be torqued up lightly but on these two bolts in particular it seems that it won't tighten at all so the thread must be worn and I don't want to strip them and make them worse.
Any tips to fix this issue gratefully appreciated!
Thanks,
DD
Member since 1996.
Official SSVC Quizmaster 2014-2018 :) :) :) :)
richandsue
Re: How do people deal with/fix stripped sump bolt threads?
Post by richandsue »
will need a Heli coil or time sert fitting to the stripped threads. prefer time serts myself.
Doka Dave
Post by Doka Dave »
Forgive my ignorance but what's a time sert?
Member since 1996.
8 8US
Post by 8 8US »
Dave
Here they are:-
https://eshop.wurth.co.uk/Product-categ ... en/GB/GBP/
I've used them for engine studs.
Can you not try some loctite on it?
Richard
1960 Single Cab Pickup “Barny” (resto thread - https://www.ssvc.org.uk/phpbb/viewtopic ... 8&t=122082)
1966 Devon “Hetty”
1980 Brasilia gone :(
Doka Dave
Post by Doka Dave »
Cheers guys, I'll give it a go!
DD
Member since 1996.
lids_2001
Post by lids_2001 »
i have threaded a bolt from the inside before and used standard nuts from underneath with some sealant in the past
Tourist exchange with optional extra of a rubber mat!
Dougie
Post by Dougie »
The studs are available from most of the usual suppliers, if it's the stud rather than the case that's suffered with age then it's an easy replacement next time you change the oil.
SSVC Club President
SSVC Committee - Membership Secretary
Who.Me?
Post by Who.Me? »
BJ1
Post by BJ1 »
WHS ^^^^^^ This is the easiest fix. Simply tap the case holes to M8 and fit the stepped studs. Stronger than helicoils etc. but don't overtighten them!
1966 SO42 Westy in Velvet Green - on the road at last!
1967 Devon from Devon still in Devon
1967 Sundial from Idaho
1971 Westfalia from LA
1971 patina Delux from Montana now living in Germany
1972 Devon now owned by No 1 son!
Doka Dave
Post by Doka Dave »
cheers guys!
Wish me luck lol
DD
Member since 1996.
unclegee
Post by unclegee »
Hiya Dave
With BJ1 on this one, it's how I got around worn threads - part no. N0144781SS from VW Heritage. Don't forget to pre-drill to 6.8mm before tapping out to M8 though!
Good luck mate,
All the best, Grant
Doka Dave
Post by Doka Dave »
Hi Grant,
cheers for the info!
I bet you don't get this problem in the Zafira lol
See ya
DD
Member since 1996.
unclegee
Post by unclegee »
:lol: :lol: :lol: :lol:
No way, that thing goes into a laboratory where its fixed by a robot with a computer!!!
e m p i
Location: Essex but I'm nothing like the twats on the telly.
Post by e m p i »
Are the threads on the studs stripped so the nuts won’t do up or are the threads in the block stripped so the stud is pulling from the block? If it’s just the threads on the studs then just pull the stud out with some grips and put a new stud in as that’s better than drilling the block out if you don’t have to.
"...scum is scum wherever you go" D.C.I. Gene Hunt
0.018 reaction time:Empster July 2005 with a timing slip to prove it
Sooty wrote: You are a god Lee. :cheers:
Doka Dave
Post by Doka Dave »
It's not studs Lee, it's just bolts. The bottom of the sump has six holes, not six studs if you know I mean.
When I go to tighten 2 of the six bolts in order to secure the sump plate on, they just spin with a bit of friction, not tighten. And this is where the oil is leaking past those threads.
Pain in the *** anyway!
Cheers,
DD
Member since 1996.
