Best way to lift an engine by hand
JonnyCJ
Post by JonnyCJ »
What's the best way to lift an engine off a dolly and onto the bench ?
I'll soon be taking my engine out for a full tin change, but not sure which bits for me and my mate to grab hold of it and get it on the bench.
Jonny
Dougie
Re: Best way to lift an engine by hand
Post by Dougie »
Exhaust front and back as close to the heads as you can get. They are not that heavy, I used to be able to lift them on my own....
SSVC Club President
SSVC Committee - Membership Secretary
ted698
Post by ted698 »
I tried and failed to lift my engine on my own - but I am a racing snake!
In my view its a 2 man lift.
Most of the weight is the flywheel - if you can get that off it makes a big difference.
Just don't lift/manhandle it by the fan housing - as that is only held on by 2 small screws and you risk damaging or breaking the oil cooler/seals.
JonnyCJ
Post by JonnyCJ »
Thanks chaps - will go with the exhaust method I think
readyboy61
Post by readyboy61 »
Dougie wrote:
Wed May 02, 2018 10:38 am
A long block I could believe but a full engine weighs close to 100kg I'd like to see you lift that off the deck onto a bench
Fixing VWs in my sleep, im not the only one right?
JonnyCJ
Post by JonnyCJ »
It is a heavy mutha hubbard...
Post by Who.Me? »
JonnyCJ wrote:
Wed May 02, 2018 1:33 pm
I was surprised at the weight difference between the early 36hp engine and my 1600 dual port. I can *just* about carry the 36hp a short distance on my own. No chance with 1600 even with my wife's help. The two of us struggle to lift it. The difference seems to be the heat exchangers. Those later style heat exchangers weigh a ton.
JonnyCJ
Post by JonnyCJ »
I'm sans heat exchangers but avec a stainless merged exhaust. Taking the exhaust off would drop the weight but give me nothing to lift with !
Mind you, twin carbs also add a bit as well.
