1641 valve clearance setting
Stevep
Post by Stevep »
Hi. Would like to know the correct valve clearance for 1641 engine Vw say 0.004 but some say 0.006 any advice please! Thanks steve
Sent from my iPhone using Tapatalk
flatbeat
Re: 1641 valve clearance setting
Post by flatbeat »
If it's got stock pushrods then 6 thou. If steel rods then you can set at 0 gap. Make sure engine is left overnight so stone cold before adjustment.
Packed a few belongings and headed out to Pirates Cove. In my buddy’s old grey Kombi we rolled until the gas got low.....
1965 11 Window aka 'Rustina'.
1961 Beetle.
JonnyCJ
Post by JonnyCJ »
Hi FB - Going to do my valve clearances in the next couple of months. Do you use sealant or just good quality cork gaskets ? I’ve heard a school of thought to use sealant on the cover side only, due to different expansion rates do the heads and the covers, but would prefer to use gaskets only if I can.
Post by vwJim »
No sealants. Just a gasket, clean heat, good cover and strong bails.
JonnyCJ
Post by JonnyCJ »
Thanks Jim
ted698
Post by ted698 »
They changed from 0.04 to 0.06 due to the smaller setting causing burnt exhaust valves - particularly on No.3
The factory increased it to 0.06 to give a bit more clearance and tolerance on the valves.
You can run 0.04 but be very careful with frequency of gap checks and note if any keep going tight - this means the valve is stretching.
Stevep
Post by Stevep »
Thanks for all your advice
Stevep
Post by Stevep »
Just serviced my bus valves set to 0.006 and is fine no extra noise. Thanks
Huw
Post by Huw »
ted698 wrote: Wed Feb 07, 2018 2:18 pm They changed from 0.04 to 0.06 due to the smaller setting causing burnt exhaust valves - particularly on No.3
Why do it then, VW say 0.06 8)
