Reduction box axle shaft wanted
PhilWhite59
Post by PhilWhite59 » Thu Jan 16, 2020 5:09 pm
Hi,
the threads on my axle shaft are badly worn - needs replacing. This is for the reduction box on my 1967 Splitty. The axle nut is the 46mm.
Does anyone have one in good condition?
thanks,
Phil
tyler
Re: Reduction box axle shaft wanted
Post by tyler » Tue Jan 21, 2020 10:35 pm
Do you still need this?
garytype2
Post by garytype2 » Thu Jan 23, 2020 9:55 am
Gary Coolcampers Image
Sent from my SM-G973F using Tapatalk
PhilWhite59
Post by PhilWhite59 » Thu Jan 23, 2020 10:02 pm
Great - I wasn’t sure if anyone would have one of these.
How much do you want for the axle shaft?
Phil
PhilWhite59
Post by PhilWhite59 » Fri Jan 24, 2020 3:32 pm
Yes, how much do you want for it?
Also just checking it's the larger 46mm nut and I perfumes it's not worn etc?
Phil
PhilWhite59
Post by PhilWhite59 » Fri Jan 24, 2020 3:33 pm
Thanks,
How much do you want for the shaft?
Phil
garytype2
Post by garytype2 » Fri Jan 24, 2020 4:08 pm
£30? With £5 post
Regards Gary
PhilWhite59
Post by PhilWhite59 » Wed Feb 05, 2020 7:39 am
Hi Gary,
So sorry for the delay in replying to you - it's been really busy with work.
I'll call you later to talk about it.
Thanks,
Phil
