autocraft detachable tow bar SOLD
If it's part of a bus for sale then post it here.
Please put buses for sale in the "Buses for Sale" section.
When something has sold please mark it AS *** SOLD ***
matty76
Post by matty76 » Wed Jan 01, 2020 5:57 pm
http://www.autocrafteng.co.uk/shop/tow- ... 58-67_477/
Hi All
Selling this tow bar which is still fitted to my bus. Used it a handful of times so practically new, just don't get the use. link above is where I bought it a couple of years ago.<br/>
any questions please ask, looking for £240 firm
Based in Maidstone Kent
66splitbusjez
Re: autocraft detachable tow bar
Post by 66splitbusjez » Thu Jan 02, 2020 12:07 pm
Hi Matty, what exhaust system are you using with the tow bar? Do you know if I can retain my vintage speed exhaust with this tow bar? It looks like it might not be compatible? Thanks, Jez
Starsky2727
Post by Starsky2727 » Thu Jan 02, 2020 8:38 pm
Depends which vs exhaust you are using. Works with the one with the exit pipe is away from the centre like this oneImage
If your has the exit pipe coming across the exhaust muffler it doesn’t fit..... unless you hit it with a hammer !!!!
Starsky2727
Post by Starsky2727 » Thu Jan 02, 2020 8:39 pm
matty76
Post by matty76 » Fri Jan 03, 2020 10:41 pm
I’ve got a tuck away under the battery tray. I’m not so sure on the vintage speed??
Post by type21f » Fri Jan 03, 2020 10:57 pm
I have autocraft detachable tow bar and side exit VS. Fits fine.
bulliboyt2
Post by bulliboyt2 » Sun Jan 05, 2020 8:21 am
Would this fit a 4 into 1 exhaust?
matty76
Post by matty76 » Sun Jan 05, 2020 2:33 pm
Sorry again I’m not sure, hopefully someone else can answer that for you!
Send over a pic so I can take a look, could hazard a guess!
boardman411
Post by boardman411 » Tue Jan 07, 2020 10:46 pm
Was going to ask the same, as I’ve got a Vintage speed exhaust as well...
boardman411
Post by boardman411 » Tue Jan 07, 2020 10:53 pm
Have you used this with a cycle rack - just wondering what the clearance is between the swan neck and rear bumper
Post by type21f » Tue Jan 07, 2020 10:59 pm
If you have a VS exhaust with side exit.. fits fine!
Maybe a slight adjustment to valance but no clash!
matty76
Post by matty76 » Thu Jan 09, 2020 6:28 pm
As starsky2627 says should fit with that type of vintage speed exhaust.
I used a tow bar type bike rack and that was fine, better than the type that rests on the tailgate which could cause damage!
boardman411
Post by boardman411 » Thu Jan 09, 2020 7:11 pm
Yes - I contacted the makers yesterday, doesn’t work with my VS exhaust, you need the side exit version..
matty76
Post by matty76 » Sat Jan 11, 2020 7:23 am
Now sold
