venting a 1915cc motor
A place for BWA'ers, wannabee's or just those with a 'passing' interest in straight line speed. (You see what we did there?)
You're gonna like us :-)
piran
Post by piran »
hi guys,
i am looking for advice and pics of anyone that has a 1915cc motor regarding venting rocker covers/oil fillers and venting to carb air filters/ or expansion tank.
i am looking to have a tidyish engine bay so am looking for ideas of the best route to have pipes/hoses etc.
also if i need to make holes in tinware for pipes will it effect the cooling at all.
many thanks
rob
Re: venting a 1915cc motor
If the engine has been built right, just something like a CB or Berg breather tower. Nothing to the rockers.
piran
Post by piran »
vwJim wrote:If the engine has been built right, just something like a CB or Berg breather tower. Nothing to the rockers.
hi jim,
bought the motor second hand running well but not sure who built it so would it be advisable to ben the rocker covers as well as have the breather tower.
many thanks
rob
lids_2001
Post by lids_2001 »
No harm in venting the rocket covers. Do it at the top corner, flywheel end. Then cut two holes in the tinware that fits over the flywheel and run hoses to the breather tower. Make sure the breather tower is vented either to carb air cleaners or a small filter so it's under atmospheric pressure.
Tourist exchange with optional extra of a rubber mat!
One advantage of not having the rocker covers vented is any slight pressure from piston blowby pushes the oil out of the head and back into the sump where its meant to be.
piran
Post by piran »
vwJim wrote:One advantage of not having the rocker covers vented is any slight pressure from piston blowby pushes the oil out of the head and back into the sump where its meant to be.
hi jim,
what about venting the engine case?
is that something you guys do and if the engine case is vented do you need to vent the rocker covers etc
many thanks
rob
As I said, if built well it won't need rocker covers venting which also makes servicing easier.
The case is already vented up the alternator stand, so if that is to a breather box or filler tower so any oil vapour drops out of suspension you can pipe that to the air filter(s).
Karl_F
Post by Karl_F »
Jim, is it still normal to get oil residue in the filters? I'm sure I'm losing oil through the carbs on hard motor way journeys, as I don't drop any oil & the motor never smokes. Normal driving never seems to result in any major oil loss.
Karl
1960 Mango 11 window
Mango build thread
Instagram & Facebook @ 73Aircooled
You sometimes get a bit in there, though not enough to effect the engine.
Stainless steel gauze in the tower helps.
