Towing Beetle on A-frame
This section is for general discussion related to VWs, and air-cooled bits ‘n bats.
Matt 6
Post by Matt 6 »
Has anyone had experience of towing a Beetle using an A-frame that mounts to the front beam?
I have seen plenty advertised over the years and I see a couple of different companies advertise them new still but they say "for emergency and short distance only"
Any advise greatly received :)
Rich
Re: Towing Beetle on A-frame
Post by Rich »
as far as i am aware beetles (unless the very oldest splits) are too heavy to legally use these a frames
anything above 700kg (if i remember correctly) should be treated as a braked trailer
Ie the the car being towed in such a way should have the brakes applied when the towing vehicles brakes come on. Probably the best way is to rent a trailer to carry the car
there's loads of posts on motorhome sites about this.
Yep, they're allowed for recovery use as far as I understand.
Though they do work well. I used something similar to tow a pickup behind a Golf. Dead easy to use.
