1500cc Rebuild
This section is for general discussion related to VWs, and air-cooled bits ‘n bats.
BusBoyT2
1500cc Rebuild
Post by BusBoyT2 »
I have the original engine for my bus under my bench in the garage. I want to get it rebuilt so I can re install it in my bus. many many moons ago it dropped a valve (yes on No.3) hence it was pulled and replaced (by a bigger cc engine)
I will be using the bigger engine for something else so need to get the 1500cc sorted.
I recently purchased some good used 1500cc heads which I intend to use.
Can someone recommend a person who could rebuild the "long block". I assume this would need completely going through, machining where required and new parts as required.
Any thoughts? (I'm in Essex)
Patrick
scottish splitty
Re: 1500cc Rebuild
Post by scottish splitty »
Hi
Patrick
Im just rebuilding a 1500 single port engine for a customers one owner matching numbers splitscreen that has been owned in the family since new.
Im rebuilding it using as many original parts as possible,have stripped and cleaned the original singleport heads amongst other parts.
Check out my builds on facebook AIRCOOLED ENGINES SCOTLAND
I can arrange engine uplift anyware in the U.k.
If its of interest call me
Paul
07842186756
AIRCOOLED ENGINES (SCOTLAND)
UNIT 5 BLOCK 1
ALLOA INDUSTRIAL ESTATE
WARD STREET
ALLOA
FK10 1ET
CREATING PLATINA SINCE 2010
Gunnsie
Re: 1500cc Rebuild
Post by Gunnsie »
Doris - 1972 Brazillian 15 Window Kombi
Gunnsie
Re: 1500cc Rebuild
Post by Gunnsie »
The VW Engine Company in SE London
http://www.thevwenginecompany.com/index.html
